I recognize this is not a high priority, but I like to keep my templates folder simple/clean. I am trying to minimize questions from user like “Which template do I use?”
- When publishing the english units asset, that will use template in the folder …\Templates\English\ANSI (in).dwg
- When publishing the metric units asset, that will use template in the folder …\Templates\Metric\ANSI (mm).dwg
This is hard coded into FDS so you must have that file in your templates folder. If you do not then this error appears when publishing an asset.
"An error was encountered while attempting to generate the 2D asset DWG.
- Failed to get the default DWG template. The Publish operation is being terminated."
IDEA
Provide a setting in "Factory Options" to define the English and Metric template for 2D Asset/Block Publishing.
