I try to install FDS 2017. but there is some error. Autodesk Factory for Vault pro 2017 can not install. the error message is that "autodesk factory for vault pro 2017 cannot be installed without vault professional 2017. Please install it prior to installing Autodesk Factory for Vault Pro 2017". How can I fix it?
I've already installed Vault Pro 2017, so I have no idea why installation process doesn't see it.
Please see attachments with screenshots and log file.
Solved by Slawomir.Drazkiewicz. Go to Solution.
Hi there,
I am sorry I didn't check the attachment that time.
After looking at the attachment,it seems that you have Factory Vault-Addin installed in your vault already. Could not you try to configure the factory asset library by Tools>-Factory configuration?
-Xuesong
Unfortunately I do not have this add-in. Repository which you see on screenshot was created from backup made by user who had Factory for Vault Pro.
There is no "Tools" -> "Factory configuration" option which I can choose.
Oleg, you can find this log in attachment.
Thanks everyone for being helpfull. Issue is solved now. Unfortunately installation packs are language sensitive. I had English versions of Inventor from FDS(U) and polish version PDM Vault Pro. I've downloaded polish installation of FDS(U) and now it works how it should. 🙂
