Hello there,
syncing layouts to Acad recently results in the following behaviour.
Any suggestions?
Hi -
Is there a specific change that you made prior to synching? Or was this an initial synch?
What does this look like in AutoCAD, after doing the synch from Inventor? Is it still incorrect?
Also, what version of FDS are you working with? 2015? 2015 with Feature Update Pack? Something else?
Thanks for the additional info.
Jeff
Hello there,
I changed the length of the conveyer that´s oriented the right way.
The other asset has just been placed with standard dimensions.
It´s the initial sync and AutoCAD wise it looks the same as the
overlay in Inventor does.
I am using 2015 subscription with the latest updates installed.
Kind regards
Daniel
It´s set up as an example to include the asset parameters via AutoCAD _DATAEXTRACTION command.
Very basic.
Also, are you using an Autodesk-supplied asset, or is this something custom that you created/published?
I am not quite sure what "include the asset parameters via AutoCAD _DATAEXTRACTION command" means... can you provide more details?
Oleg
