Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Object reference not set to an instance of an object
4 REPLIES 4
Logos_Atum
496 Views, 4 Replies
Hello there,
recently out asset library did get some addons, in order
to use the BIM with some of the company´s custom tools.
With some time at hand, I planned to use an Excel table
with all the asset specific data as a base for new assets, as
well as base to add customer specific dimensions in a quick
manner.
It´ll not be necessary to change any model data Inventor
wise now, and live links with customer databases can be
established and applied to the assets directly. Changes in
equipment, as well as the dimensions and other metrics,
will be updated too.
And with the parametric modelling offered in FDS we should
just do fine. Allocating the right amount of square footage is
crucial, especially in logistics.
I encountered a problem, and currently I seem to be stuck in
my tunnel all to much to see.
Injecting/adding the following code I got an...
'creating an userParameter as millimeters
oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
oParameter=oMyParameter.AddByExpression("width", "1000", UnitsTypeEnum.kMillimeterLengthUnits)
oParameter=oMyParameter.AddByExpression("height", "1000", UnitsTypeEnum.kMillimeterLengthUnits)
'creating an userParameter as text
oParameter=oMyParameter.AddByValue("speed", "0", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("motors", "0", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("ID", "0", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("ID_FCC", "0", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("ID_PQC", "0", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("ID_OWC", "0", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("ID_WC", "0", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("ID_B", "0", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("ID_LUA", "0", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("ID_IO", "0", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("ID_CSS", "0", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("ID_MAS", "0", UnitsTypeEnum.kTextUnits)
oParameter=oMyParameter.AddByValue("ID_SD", "0", UnitsTypeEnum.kTextUnits)
'Setting Parameter values by an excel source file
GoExcel.Open("d:\FDS20.xls", "Sheet1")
MultiValue.List("width") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "L1", "O1")
MultiValue.List("speed") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "R1", "Y1")
MultiValue.List("motors") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "Z1", "AB1")
MultiValue.List("ID") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "E1", "G1")
MultiValue.List("ID_FCC") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "AC1", "AE1")
MultiValue.List("ID_PQC") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "AF1", "AH1")
MultiValue.List("ID_OWC") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "AI1", "AK1")
MultiValue.List("ID_WC") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "AL1", "AN1")
MultiValue.List("ID_B") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "AO1", "AQ1")
MultiValue.List("ID_LUA") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "AR1", "AT1")
MultiValue.List("ID_IO") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "AU1", "AW1")
MultiValue.List("ID_CSS") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "AX1", "AZ1")
MultiValue.List("ID_MAS") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "BA1", "BC1")
MultiValue.List("ID_SD") = GoExcel.CellValues("d:\FDS20.xls", "Sheet1", "BD1", "BF1")
'limiting parameter values
If height < 450 then height = 450
"Object reference not set to an instance of an object"
 error message that terminates the publish operation.
I tested a variety of the following:
  • looked for units conflicting geometry
  • delete rule after it ran
  • add custom values for multi text Parameters
  • empty values assigned - rebuild
  • iproperty mass
Added:
  • InventorVb.CheckParameters("")
  • Parameter.Quiet = True
  • InventorVb.DocumentUpdate()
  • ThisDoc.Save
Without any errors returned, still Publishing is canceled
I´t be great if it´d be possible to help me a bit.
Kind regards
Daniel
Dogs aren´t flammable.
4 REPLIES 4
yizhou.cao
in reply to: Logos_Atum
Hi Daniel,
I am not following. Is your code in a logic rule? Can you attach the part you are trying to publish, as well as the spreadsheet?
Yizhou C
Autodesk Factory Design team
XuesongBai
Hello Daniel,
Good to hear you again.
The asset linked to Excel is not supported right now.
Could you please post the idea in the Factory IdeaStation?
  • Why you are doing?
  • What benefit from what you are doing now?
-Xuesong
Please mark as a solution if somehow I got it right.
Logos_Atum
in reply to: yizhou.cao
Hello yizhou,
it is a rule, yes.
And it is deleted right after it ran once. Still the publish
fails, even if it´s simply a cube, with some Parameters ad-
ded
Kind regards
Daniel
Logos_Atum
in reply to: XuesongBai
Hello Xuesong
Long time not read, yes 🙂 I´ll post it to the idea station,
in a minute.
Removing the script after the parameters were created,
did not settle the issue though.
I did attach a helper object.
Kind regards
Daniel
