I would like to add AutoCAD to the FDS launchpad? Is it possible?
In the FDS deployment I can add a AutoCAD profile to the desktop, but it does not appear in the launchpad?
Can I modify it after the installation?
Regards Andreas
Solved by XuesongBai. Go to Solution.
Hi AnJanson,
Maybe the answer is no. You cannot customize the launchpad.
-Xuesong
I'm sorry, but I have to come back again to this issue.
The launchpad in FDS 2016 starts AutoCAD with the following command Line parameters:
"C:\Program Files\Autodesk\AutoCAD 2016\acad.exe" /ld /p "" /product "ACA"
Because there is no profile defined, AutoCAD starts with the last profile used.
That means, if I last used the basic AutoCAD profile the launchpad starts AutoCAD.
But if I last used the AutoCAD Architecture profile it starts ACA again.
Is there any possibility to add a named profile to the parameter /p in the launchpad?
I would like to force the launchpad to always start AutoCAD Architecture, no matter which profile was used before.
Regards
Andreas
Here is a shot of my Launchpad.
