Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
How can I use Factory properties of an Factory asset in Architecture or Mechanic
8 REPLIES 8
Message 1 of 9
TAR_Loki
518 Views, 8 Replies
Hello together,
is there anypossibility to use the Factory properties of an asset also in Architecture or Mechanical.
I tried it, but I didn't found something.
I insert a system object, marked it and no property was shown like in Inventor.
What did I wrong?
Kind regards,
Sven
Tags (1)
8 REPLIES 8
Message 2 of 9
XuesongBai
in reply to: TAR_Loki
Hi Sven,
Which version of FDS are you using now?
If my memory served me well, the factory properties in ACM/ACA like in Inventor is available starting from FDS 2016 R2.
-Xuesong
Please mark as a solution if somehow I got it right.
Message 3 of 9
TAR_Loki
in reply to: XuesongBai
Hi Xuesong,
at the moment I am using FDS 2016 64 bit
Build 236, Release 2016 SP2 Update 1 - Date: Tue 07/19/2016
Gretings,
Sven
Message 4 of 9
XuesongBai
Hi Sven,
That is it. You need to install FDS 2016 R2(aka Feature Update Pack) separately which is only available for subscription users.
-Xuesong
Message 5 of 9
TAR_Loki
Is there any possibility to update my version?
Message 6 of 9
XuesongBai
Depends on you if you are the subscription user.
-Xuesong
Message 7 of 9
TAR_Loki
Yes I am Smiley Happy
But which update is it.
There is no Update show for the FDS with R2.
Only Inventor R2.
Message 8 of 9
petestrycharske
TAR_Loki,
Good morning!  Not sure if you've been able to find this already, but wanted to help if I still could.  You are in the right area, but have to click on the Product Enhancements as I show in the image below.  You should be able to find it from there.  If you have any questions, please do not hesitate to contact me.  Hope this helps and have a most blessed day!
Peace,
Pete
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
Message 9 of 9
TAR_Loki
in reply to: petestrycharske
Thanks alot!
That was what I was searching for.
It is a little bit confusing, that I have to search for that ipdate, on a different place.
