Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Hotfix to Factory Ribbon missing in FDS 2017
4 REPLIES 4
XuesongBai
1125 Views, 4 Replies
Dear Factory users,
In case you have applied the AutoCAD Vertical SP1 to FDS 2017. You encountered the issue that the factory ribbon UI is missing. That is konwn issue and the hotfix is available now. You can get it from https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autoc...
Sorry for the inconvenience taken to you.
-Xuesong
Please mark as a solution if somehow I got it right.
4 REPLIES 4
nstalker
in reply to: XuesongBai
how do you fix this with 2018?
olegd.prod
in reply to: nstalker
This exact same issue doesn't exist in 2018, since 2017 SP1 is included in 2018.
What is the issue you are running into? The Factory ribbon isn't there? Partially there? Buttons are not working? etc
olegd.prod
angela.cao
Hi nstalker,
Not sure this will solve your problem, but if your Factory ribbon is missing, you can always try following the steps here and see if the ribbon displays.
Angela Cao
Angela Cao
Autodesk Learning Content Designer
