Good day Everyone!
I hope you can help me with my simulation. By the way I work in a foaming company. In my process, I have a source (long split/trimming machine), 4 circular machines (each should be loaded with 8 short foam blocks before starting) and a single take-away machine (which is not a problem because it can only process 1 short block at a time.
I thought of assuming that a single raw material is equal to 8 short blocks, I just have to change the loading/unloading time and the processing time.
But I think the idea of simulation and see how things will work will not be seen in my model if I do that.
Thank you very much!
Solved by liqinomickey. Go to Solution.
Hi there,
Thank you for using PA. Currently I do not have a perfect solution for your issue, but several imperfect ideas:
Out of curiosity, may I ask what output routing did you set with the source?
Mickey
Mickey.Li@Autodesk.com
Hi Mickey,
Thank you very much for the solution. I'll just adjust and tweak some processing time to make my simulation more realistic.
Setting the lot size is really helpful. Adding a processor after the four cutting machines is something I forgot to do(I'm still in the process of learning to use this cool simulation software) . These four cutting machines'output will use the same conveyor so adding a processor is a great idea. BTW,Is it just right to use a buffer for my conveyor?
I used "shortest queue" for source output routing. This software is really cool and user friendly.\
Thank you very much for the knowledge man.
Glad I could help, and more glad our software could help!
"BTW,Is it just right to use a buffer for my conveyor?"
As you might have noticed, there is also a property in Connection, CAPACITY. This property will allow multiple items (lots) exist in one connection, which we would like to simulate a conveyor.
But if you would like to use a buffer to simulate conveyor,
Thank you for using our software and please keep feeding us back, so we could improve our software towards your needs!
Mickey
Thank you very much Sir Mickey! Sorry for the late reply for I was tasked to work on another project in a remote plant. Nevertheless, I was able to get the results I need. Thank you very much for the tips. I'll keep on posting questions on this community and I am really excited how this software will improve in the next 2 years.
I think my merger doesn't work correctly. It always sends the product to the next processor aside from the action type what do I have to set to make it merge 18 blocks before sending it to the circular cutting machine?
Sorry, I didn't quite get your issue. Are you talking about Operation 29, could you send a property snapshot of that processor? Or if it is possible, could you send a model adskfpa file to me?
Mickey
Sure thing. I tried tweaking the minimum quantity for each processor to achieve what I want but I still can't make it. I hope you can help me my friend. Thank you very much.
What Kenny asked you to change was attached "screenshot1".
What Xuesong was aksing you to do was to get rid of the Merge and splitting processor. Instead, using a connection lot size to simulate the 18 item process. "Screenshot2"
I think, in both ways, the issue could be solved.
Mickey
Wow! Thanks man! It's now what I want to see Thank you very much for the great help! You just made my day!
Cheers! May I ask a favor? When you have time, could we set up a conference call or something. We would very much like to know how our software solved your real case. Thank you!
Mickey
Woah! That would be cool! I'll let you know when I will have the time. I need to finish 3 more options for my proposed product line and their CAD layout, too. I'm really looking forward to that! Thank you very much.
EDIT:
I am also trying to animate it in Cinema 4D I think that will help our future conversation go smoother. Thanks again man.
