Hello there,
Is it possible to implement the use of driven dimension as a valid imput in equations 🙂
I kind of like the idea to be able to use the output of a geometry change without equations,
or use the respective value of the driven dimensions parameter in the rest of the design process.
Cyclical dependencies though might be a real problem if you don´t keep track.
