Existing 2D layout block replacement with asset
We would like to see the posiblity to list in an existing 2D DWG layout all 2D blocks (already possible in FDS2015 R2) and map the blocks with already published 2D or 2D+3D factory assets based on corresponding naming or select manually and suggest replacing with the factory assets. This is now only possible after publishing of the asset.
6 Comments
XuesongBai
The Replace with Asset command is available starting from FDS 2016 R2.
XuesongBai
joaopirotta
Hi all, where can I find this option?
strijkp
Hoover over the block you want to be replaced by an asset. RMB -> Factory -> Replace with Asset
strijkp
[cid:image001.png@01DA0D7E.C2BBAA10]
joaopirotta
Hi @strijkp thank you for sharing!
