Factory Design Suite General Discussion
Valued Mentor
Logos_Atum
Message 1 of 11 (293 Views)
Using part parameter in factory assembly
293 Views, 10 Replies
07-30-2012 06:24 AM
HEllo there,
how can i use a part parameter which is in an asset in a factory assembly.
The array command is to accept the input of the width parameter of the asset.
Ilogic to be used?
- 2500K @ 4.2Ghz- 8GB - Radeon7970 -
- 2x Xeon 2670V2 - 64GB - W7000 - 4x Quadro 2000 -
- Factory Design Suite Premium Subscription-
OK,Please send me the file by Xuesong.bai@autodesk.com
-Xuesong
Hi Daniel,
Please use the name of occurence in the browser,say Regal DT:1.
Breite=Parameter("Regal DT:1", "Breite")
-Xuesong
Employee
XuesongBai
Message 2 of 11 (271 Views)
Re: Using part parameter in factory assembly
07-30-2012 08:36 PM in reply to: Logos_Atum
Hi There,
Yes, we need to link the parameter of asset in factory layout by iLogic. The sample iLogic code is as
d3=Parameter("iLogic Control:1", "Length")
 And link the value in the array in layout assembly.
Please see the details in the snapshot attached.
-Xuesong
Valued Mentor
Logos_Atum
Message 3 of 11 (267 Views)
07-30-2012 11:16 PM in reply to: XuesongBai
Mr Xuesong - what would i do without you - thank you very much for your professional expertise and great answers. Im working on the solution right now
Bless you :smileyhappy:
Valued Mentor
Logos_Atum
Message 4 of 11 (264 Views)
07-30-2012 11:26 PM in reply to: XuesongBai
I trying but maybe you can help me one more time.
Do i need to define a rule in the asset too?
Valued Mentor
Logos_Atum
Message 5 of 11 (262 Views)
07-30-2012 11:36 PM in reply to: Logos_Atum
Where to define "ilogic Control:1" ?
This is the first time i´m using i logic - be patient.
I am all glad that it´s possible to do this but i need advise still
Employee
XuesongBai
Message 6 of 11 (258 Views)
07-31-2012 12:02 AM in reply to: Logos_Atum
Hi There,
you need not to define the ilogic in the specific asset. It is OK to define it in layout assembly. "iLogic Control" is just name of a part which is placed in the assembly and the parameter of the part will conrol the array. Once the value of part parameter is changed, the array will be updated too. Maybe you need to run the ilogc rule and update the document manually.
Anyway, I attached the simple sample for your reference.
-Xuesong
Valued Mentor
Logos_Atum
Message 7 of 11 (255 Views)
07-31-2012 12:16 AM in reply to: XuesongBai
Thank you - i ´m working on it... perhaps i will ask some more questions :smileywink:
Great support!
Valued Mentor
Logos_Atum
Message 8 of 11 (250 Views)
07-31-2012 12:45 AM in reply to: XuesongBai
I decided to send you the problem i´m working on...
Perhaps this will clarify it for me for i know the matter better.
I don´t know yet which files to include for the pack and go to work properly, so i had a look into your zip file.
It´s in german- ask me whatever you need to know. The box needs to be the source for the array´s offset to prevent the boxes to overlap.
As long as you look into my problem i will look into your example.
Thanks in advance
Employee
XuesongBai
Message 9 of 11 (248 Views)
07-31-2012 12:51 AM in reply to: Logos_Atum
-Xuesong
Valued Mentor
Logos_Atum
Message 10 of 11 (239 Views)
07-31-2012 04:14 AM in reply to: XuesongBai
Hello there,
there still is a problem getting the asset name.
The program tells me there is no such instance.
I will send the corresponding files to you and hope to get this issue resolved
