I just installed FDS 2014 and when I upload an assembly, none of the associated parts go with it. I thought 2014 automatically included all associated files. What am I doing wrong?
Hi there,
I guess that you were uploading the assembly inside A360 weg page. For the Inventor assembly file, I suggest that you upload the file by A360 client(Autodesk 360).
1,RMB A360 client and select Open A360 drive (%localappdata%\Autodesk\Autodesk Sync )
2,Drag and Drop the assembly file to the folder
3, All references will be found and then uploaded to A360 with assembly file
By the way, if you want to share the assembly with others in A360, the references cannot be shared automatically. So I think you better pack and go all files in Inventor and Zip them and then upload the zipped file into A360.
-Xuesong
