Heey all,
When I have created an custom connection class and I use this custom class in an asset, all the parameters of my choice will be copied to the second assed when I link it to the first one.
Now I'm wondering, is it possible to turn this connection class on/off while using it in a layout. So for instance, when I have asset number 1 with a length of 1000mm and a width of 400mm, and I want to connect asset number 2 to asset number 1 but I dont want asset number 2 to copy the length but I do want it to copy the width, or for instance I do not want it to copy any parameters at all.
And for instance when I want to connect asset numer 3 to asset number 2 I do want it to copy the width and length of number 2. Asset number 1, 2 and 3 are all the same asset, placed multiple times.
Is this possible? Thanks in advance,
Robbert
Solved by Blokkie862. Go to Solution.
Hi Robert,
You can not do that unless the assets 1,2,3 are different assets.
-Xuesong
Oke thanks for the quick answer. Too bad that it isn't possible.
Robbert
