Hi
I get the following warning:
"The template file you are using to create the new document needs to be migrated. Please open it and explicitly save it before using it to create any documents"
This warning occurs both when I'm publishing asset (during 2D representation generation) and synchronization of a structural, mechanical dwgs. (although the architectural dwg I created, started from a 2004 autocad dwg)
I already have tried to update as many templates as I could find, but it still doesn't work. Can you tell me which one I have to migrate?
Kind Regards
Peter
Hi Peter,
Please give a try to migrate the following dwg template that in Inventor.
C:\Users\Public\Documents\Autodesk\Inventor 2013\Templates\Metric\ANSI (mm).dwg
C:\Users\Public\Documents\Autodesk\Inventor 2013\Templates\English\ANSI (in).dwg
-Xuesong
