Hello there,
just a simple question: can I publish a movie
showing the behavior animations I did with
showcase?
Would be great!
Kind regards
Daniel
Solved by XuesongBai. Go to Solution.
Hi Daniel,
Yes, you can. The following steps you need to do.
1,New Storyboard Slide and add the behaviors animation to the slide
2, Save silde as Movie on the RMB menu on the slide
-Xuesong
Hello Xuesong,
again- thanks for the quick help.
I will try to ddo so tomorrow, and
let you know if I managed to.
Kind regards
Daniel
