Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Show actual value of a computed parameter
5 REPLIES 5
Logos_Atum
411 Views, 5 Replies
Hello there,
i did an asset with an array in it. Usually the computer calculates
the number of copies dependent on the space there is by a formula
which includes rounding. Anyway sometimes you might want to add
or remove an element.
Is it possible to display the actual number, the calculated value of
the array? If not it would be nedessary to count them before using
an absolute value.
Roller distances are fixed.
Is this possible?
Kind regards
Daniel
Dogs aren´t flammable.
5 REPLIES 5
Logos_Atum
in reply to: Logos_Atum
I meant the value of an equation...
XuesongBai
Hi Daniel,
I didn't quite understand what you mean. But i guess you can use Distance option to pattern the features in the asset since the distance is fixed. Anyway, could you please share a sample to look close?
-Xuesong
Please mark as a solution if somehow I got it right.
Logos_Atum
in reply to: XuesongBai
Hello Xuesong,
so good to have you back! Yes distance patterning might help and I
most certainly will try.
There´s just one more question. If i put a value, and check "key", it´s
displayed as a key parameter. If I put an equation and check "key" only
the equation or the parameters name is listed. I would want to see the
actual value of the parameter.
I attached a screenshot. Perhaps i´m allowed to change to distance.
Would be a little easier that way.
XuesongBai
Hello Daniel,
That is as designed that If you  put an equation and check "key" only the equation or the parameters name is listed. I don't know why you want to display the calculated vaule in the list. All of prameters that shown up in the list as key parameter should be the drive parameters.
If you really want to display the vaule of such key parameter that is driven by equation,so please put the equation in iLogic, rather than in parameter list.
-Xuesong
Logos_Atum
Hello Xuesong,
thank you so much, I´ll try to do that.
Kind regards
Daniel
