Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Setup troubleshoot
4 REPLIES 4
Sprocket107
414 Views, 4 Replies
Setup troubleshoot
Hye.
I use to be able to place assets in my layout without trouble. I placed part assets as well as assembly assets. But I should have change something in my setup because I can not place assembly assets no more. (part assets still works fine). As soon as I placed a assembly asset, Inventor 2014 crashes.
I would like to know if there is anyone who can tell me where to look for to troubleshoot my setup to be able to place assembly assets again.
Andre
4 REPLIES 4
XuesongBai
in reply to: Sprocket107
Hi there,
Actually there is no specific setting for placing assembly asset.
Could you share me a video of the workflow you are using now?
You can send it to Xuesong.bai@autodesk.com.
-Xuesong
Please mark as a solution if somehow I got it right.
Sprocket107
in reply to: XuesongBai
Hi Xuesong
Yes I will share you a video of the workflow I'm using. In the meanwhile, is the location of the "Factory Assets" or "Factory Library" directories important? Is the location of my IPJ file important? Is the templates and Design Data could be the source of my problem? Or maybe something in Factory Option?
The video will show the placing of the system asset "MEZZANINE" (or any assembly asset) and then... crash. (I can not send it now but I will tomorrow).
The placing of any part asset works fine.
Thank you very much
Andre
yizhou.cao
Hi Andre,
Did you send a crash report to Autodesk? When you do so, please fill out the email address and add some comments so we can look it up.
Yizhou C
Autodesk Factory Design team
Sprocket107
in reply to: yizhou.cao
Hi
Since I wrote to Autodesk Factory Design forum to ask for an advise about my trouble, I found that there is an application newly installed on my PC which is the cause of crashing Inventor.
So I’m working now into this new application to fix my problem.
Now I know that Inventor factory 2014 is working fine.
No need to spend more time on this case.
Thank you all
Andre
