Hye.
I use to be able to place assets in my layout without trouble. I placed part assets as well as assembly assets. But I should have change something in my setup because I can not place assembly assets no more. (part assets still works fine). As soon as I placed a assembly asset, Inventor 2014 crashes.
I would like to know if there is anyone who can tell me where to look for to troubleshoot my setup to be able to place assembly assets again.
Andre
Hi Xuesong
Yes I will share you a video of the workflow I'm using. In the meanwhile, is the location of the "Factory Assets" or "Factory Library" directories important? Is the location of my IPJ file important? Is the templates and Design Data could be the source of my problem? Or maybe something in Factory Option?
The video will show the placing of the system asset "MEZZANINE" (or any assembly asset) and then... crash. (I can not send it now but I will tomorrow).
The placing of any part asset works fine.
Thank you very much
Andre
Hi Andre,
Did you send a crash report to Autodesk? When you do so, please fill out the email address and add some comments so we can look it up.
Hi
Since I wrote to Autodesk Factory Design forum to ask for an advise about my trouble, I found that there is an application newly installed on my PC which is the cause of crashing Inventor.
So I’m working now into this new application to fix my problem.
Now I know that Inventor factory 2014 is working fine.
No need to spend more time on this case.
Thank you all
Andre
