Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Send to Inventor Button - iLogic Rules and Forms Omitted
2 REPLIES 2
CadlineSupport
559 Views, 2 Replies
When using the 'Send to Inventor' button in AutoCAD Architecture, the iLogic rules in my Factory Layout template are not brought in to the new Layout created. I have selected the desired template in the Templates tab of the Inventor factory options, is there another location that I need to specify the template to be used? All the iLogic is brought in as expected when creating a new Factory Layout from template as normal from Inventor so this seems to be a problem with the 'Send to Inventor' button itself. Can anyone advise?
2 REPLIES 2
XuesongBai
in reply to: CadlineSupport
Supposed you are using the Win 7 OS.So there is two templates for Metric and Imperial in the C:\Users\Public\Documents\Autodesk\Inventor 2012\Templates\Factory. You need to create the ilogic rule in them. So if you new 2D layout in ACAD by Metric template, then Send to Inventor will select the 3D metric template too. Vice versa.
-Xuesong
Please mark as a solution if somehow I got it right.
CadlineSupport
in reply to: XuesongBai
Superb! Thank you very much for your help Xuesong.
