Factory Design Suite General Discussion
Active Contributor
3 Kudos
Post 1 of 3
Send to Inventor Button - iLogic Rules and Forms Omitted
288 Views, 2 Replies
03-08-2012 08:21 AM
When using the 'Send to Inventor' button in AutoCAD Architecture, the iLogic rules in my Factory Layout template are not brought in to the new Layout created. I have selected the desired template in the Templates tab of the Inventor factory options, is there another location that I need to specify the template to be used? All the iLogic is brought in as expected when creating a new Factory Layout from template as normal from Inventor so this seems to be a problem with the 'Send to Inventor' button itself. Can anyone advise?
Supposed you are using the Win 7 OS.So there is two templates for Metric and Imperial in the C:\Users\Public\Documents\Autodesk\Inventor 2012\Templates\Factory. You need to create the ilogic rule in them. So if you new 2D layout in ACAD by Metric template, then Send to Inventor will select the 3D metric template too. Vice versa.
-Xuesong
Employee
55 Kudos
Post 2 of 3
Re: Send to Inventor Button - iLogic Rules and Forms Omitted
03-08-2012 05:57 PM in reply to: CadlineSupport
-Xuesong
Active Contributor
3 Kudos
Post 3 of 3
03-09-2012 01:15 AM in reply to: XuesongBai
Superb! Thank you very much for your help Xuesong.
