I have a Revit model exported to a. SAT file.
The model I loaded in FDS.
In the model there are two ceiling levels.
Now I want at any level a layout.
I tried this in the way in the 2012 version but I see the command Add Dwg Overlay is no longer to add a dwg to the level.
I would not know where I should get a dwg from as I work with a 3D model.
I also have a second new layout created and placed in the main assy but I can not persuade the contours of the walls.
I would like in the 3D model from Revit place my ceiling panels to the different levels.
Is there a way to post the layouts with the contours of the wall so I can place my panels on the different levels?
See the files in the dropbox link:https://www.dropbox.com/sh/gsue0k47j9nll0k/YuhLZmmlkb
Hi Jos,
Maybe you need to manually add the dwg as overlay in Inventor and then Create Sub layout based on the main layout.
-Xuesong
