Factory Design Suite General Discussion
strijkp
Message 1 of 6 (256 Views)
Prioritize Connector snap when making roundtrip Sync
256 Views, 5 Replies
07-24-2012 04:32 AM
Is there a methode to prioritize connector snaps prior to groundplane snaps when Sync from ACAD?
In my video attached, you can see assets that are placed on top of each other, fall back down on the floor after Sync from ACAD in stead of staying connected to the connectors.
Xuesong validated that it is a regression issue on SP1, we are looking at it.
Active Member
AnJanson
Message 2 of 6 (248 Views)
Re: Prioritize Connector snap when making roundtrip Sync
07-24-2012 09:40 AM in reply to: strijkp
Are you using SP1? I think this is a bug and came with SP1.
I have a similar problem.
I have placed a standard folklift from the library, added a standard palette on the fork. The palette was placed with constrains to the fork face. After a sync from Inventor to AutoCAD and back, the palette is on the floor.
I have done this severel times before without any problem. This does not work anymore since I have installed the SP1.
I have already send this to the Autodesk support. I am waiting for a reply.
The video shows the effect
Employee
XuesongBai
Message 3 of 6 (244 Views)
07-24-2012 05:52 PM in reply to: strijkp
Thanks for providing the hint. I will check what happen in SP1.
-Xuesong
Employee
tanghong77
Message 4 of 6 (233 Views)
07-25-2012 07:32 PM in reply to: strijkp
Valued Mentor
Logos_Atum
Message 5 of 6 (221 Views)
07-26-2012 04:44 AM in reply to: tanghong77
Will be glad if this is solved... i have the same problem here...
- 2500K @ 4.2Ghz- 8GB - Radeon7970 -
- Xeon 1230V2 @ stock Ghz- 32GB - W7000-
- 2x Xeon 2670V2 - 64GB - W7000 - 4x Quadro 2000 - oh yes -
- Factory Design Suite Premium Subscription-
New Member
MrPaukas
Message 6 of 6 (133 Views)
08-23-2012 06:48 AM in reply to: Logos_Atum
I also have the same problem and error message. I installed all the hotfixes that you've published up to now - but the bug still exist...
Would be great if you provide a hotfix or something else soon.
Best regards,
Paukas
