hello,
i m modeling in inventor 2014.
how can i open inventor 2013 this file.
it has any option in inventor 2014 saving in inventor 2013.
Hello there,
not in a native format I guess
Kind regards
Daniel
thats an autocad function
you can export to a .stp file and open in 2013
but you will lose your feature history
DarrenP
HI there.
It not possible to send an IPT file from a New version to an old version of Inventor. But It works the other way around, if you have and IPT 2012 and open with Inventor 2015 no problem. it works like charm.
However, the best options to send a file from an early version would be .STEP, IGES.
Hope it helps
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
