I just upgraded to the last NLM v11.12 and installed the last license for ADFS 2015. Everything seems to be in order on the server box, however the client box/software do not see ther server. I can ping ther server and the ports look to be open. What can I check next?
JeffB
Honestly I encountered the same problem with two different solutions:
When FlexLM requests the licence server name type in the servers IP- not its name. Should be the same- yet is´n´t.
Worked only that way the last time we ran into this. I suspect because a seperate MAX licence was issued from the
same server with a different licence server version.
The other scenario we came across something alike was, even though able to ping the server, no licence could be
obtained because... we forgot to add an exeption to the Windows firewall.
I hope you´ll find this helpful
Kind regards
Daniel
