Is there a "switch" that can be set that will allow Navisworks to be loaded without the FDS Tools? And then a alternate "switch" to load the FDS Tools?
I have a significate slow down in performance of Navisworks with the FDS Tools loaded. And it is a bother to Uninstall/Reinstall to accomplish the same thing that a "switch" would do.
Solved by guosu. Go to Solution.
Hi Dennis,
Currently there is no way to unload Factory Utility for Navisworks quickly. Could you please try to uncheck Floor Visible, Grid Visible and Snap to Model, Snap to Grid in Options Editor dialog firstly? If it still can't improve the performance, please share your data to us if convenient then we can investigate the issue. We will treat your dataset as confidential.
Sucy
I tried turning off the settings you mentioned. Seems the Grid Display is the main culprit. I can turn the Floor back on and it seems fine. But as soon as I turn on the Grid Display, I get the spinning blue circle of death and Not Responding.
Hi Dennis,
Thank you for your reply. I try to open a simple factory layout file, and turn off Grid Display then turn on. But it seems work well. So is it convenient for you to share the file with us then we can have a look? We will treat your dataset as confidential.
Sucy
Latest update: Here is what I discovered. First off, it was giving me the crash and burn with no data set loaded. So, it wasn't a particular dataset. Then I discovered the AutoSize of the floor was godzilla-huge, miles and miles. So I changed the size to 50 feet square. Turned on the grid with no problem then. Now, the only thing I need to fix is the orientation of the floor. It is ortho to the right-side (or left, not sure which is up) of the view cube rather than the top. When I try to set any other view as Front, via the right-click, nothing happens.
Any suggestions on the orientation?
Hi Dennis,
You don't need to adjust orientation by yourself. If you sync Navisworks from AutoCAD or open Inventor Layout file directly in Navisworks, it will adjust the orientation automatically. Floor will be seen in Top view.
please ignore the last post form me.
I replied to this thread via email almost a month ago, and it looks like the forum system just now processed that email
