Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Inventor synchronization fail, when chain assets are using.
2 REPLIES 2
Slawomir.Drazkiewicz
335 Views, 2 Replies
I've got problem with AutoCAD -> Inventor synchronization.
When I'm using standard assets everything works great, but when I try to use chain assets synchronization failed,
Example:
1. I open new AutoCAD dwg drawing.
2. I place "not chain" asset.
3. I synchronize drawing with Inventor. Everything works fine.
4. I synchronize draving to AutoCAD.
5. I place chian asset.
6. I synchronize drawing with Inventor. Chain asset doesn't show. 😞
7. I synchronize drawing with AutoCAD. I delete chian part and place some other "not chian" asset.
8. I synchronize drawing with Inventor. Everything works fine again.
2 REPLIES 2
Hi there,
Which one "chain asset" are you using now?
-Xuesong
Please mark as a solution if somehow I got it right.
It doesn't matter. All "chain" assets don't work properly. Doesn't matter which one I used.
