Hi
I had this issue last month and I was unable to recall the worflow.
Now I do:
1-My part is open in Inventor and saved. The landing surface, insertion point and connectors are set.
2-My customized connector class file is open in edition mode.
3-I added some new lines in the file and save, but remind open.
4-In Inventor, click on "Asset Builder", then click on "Connector Class Properties" and then CRASH.
Please Xuesong, could you look at it again?
Thanks a lot.
Andre
Solved by XuesongBai. Go to Solution.
Hi Andre,
Sure. It is my duty to look at the issue.
Could you please share the connectorclass file you are using?
And that will be helpful to give the new lines code you want to add into the connectorclass.
-Xuesong
Hi Andre,
I don't know when we can enhance the capacity of error detective in the connectorclass properties.
But to be sure, we will do it in the near future release if we reproduce the issue with your test data.
To mitigate the inconvenience that will be taken to you.
Here is the method to restore the asset.Please Copy the code in the VBA in the asset.
Sub Restore()
Me.PropertySets.Item(5).Delete
End Sub
And run it.
-Xuesong
Hi -Xuesong
Thank you for the VBA code.
I will be able to try it next monday and also send you my connector file.
I'll keep you in touch.
Andre
Hi -Xuesong
Good morning and thank you very much again, everything is working fine.
I'll keep the code in case of further bug.
Andre
