i wish to instal the trial of the factory design suite 2014 . If i start the install i always get the following error.
My machine is a brandnew i5 Notebook with win8 and 1600 x 900 graphics. I have administrator rights.
Hello Christian!
Can you try utilizing a different download / delivery method and let me know if that resolves the issue,
specifically Browser Download.
You can access most current + previous supported version Browser Download links (including the Factory Design Suites) through Matt, our Virtual Assistant.
From Matt: Download and Installation -> Software Download Links -> I need to redownload my product
Thank you very much for your help. It probably works, but i can only download the English Version. I want the German Version of the suite.
I have load the installation. The install produces an error and it does not work. I have no idea how to solve the problem.
I've just sent you a Private Message with the FDSU 2014 German direct download links.
thank you for your help. It wasn't the solution of the problem. It seems to be the length of the temp-directory path. I changed it in my system to c:\temp and when i restarted the setup it worked without any problems. Perhaps its a good idea to check out the field-length in your install. In my case it was 182 signs before the change which seems to be to long for the autodesk install-program.
Perhaps this solution will help. I found different posts with the same problem in other places while i was searching for help.
I tried installing the factory design utility but I keep getting an error message saying my laptop doesn't meet the minimum specification. Is there a way to work around this? The processor base speed seems to be the problem. I will appreciate any valuable input thanks
Hi @Anonymous
Would you please paste the specifications of your current machine? Thank you.
May I know if you installed any FDU host app before installing FDU 2022? you need to first install at least one of below host apps.
Inventor Professional 2022
AutoCAD Mechanical 2022
AutoCAD Architecture 2022
AutoCAD MEP 2022
Navisworks Manage 2022
Vault Professional 2022
Did it work after you installed one of the FDU host apps? I installed AutoCAD Mech 2022 but still gives me the same error. Any idea why?
