Can I install Factory Design Suite Ultimate And Product Design Suite together?
I have installed Product Design Suite Ultimate 2014 and I want to install Factory Design Suite Ultimate 2014
You sure can Karina!
Either way should be fine, but just as a rule of thumb you would typically you would want to install the suite with the most products, or the one with the most products that are also contained in the other suite first. Regardless the installer should be able to detect if an increment is already present.
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information!
