Factory Design Suite General Discussion
Active Contributor
patrick.fillion
Message 1 of 2 (121 Views)
How to debug a new chain asset
121 Views, 1 Replies
09-13-2012 01:14 PM
I have create a chain asset with straigth and corner asset, that works fine. I try to create an other one using and when I use it as chain asset, I get the polyline in Autocad but nothing is comming accross in Inventor. I can insert a 2d block and that will transfert, I can insert from the 3D. The connectors works. So, in that case, How do we do debugging as the chain creator is web base???
Employee
XuesongBai
Message 2 of 2 (116 Views)
Re: How to debug a new chain asset
09-16-2012 06:02 PM in reply to: patrick.fillion
Can you share you straight and corner assets with me and also share your .assetchaining file? You can send to me by xuesong.bai@autodesk.com
-Xuesong
Post to the Community
New Post
Need installation help?
