Hi all,
I am new to the Autodesk Factory Design Suite, currently working on building a library of assets for a manufacturer. Is it possible to add energy consumption properties to different assets and their variants? Also, how do you perform an energy consumption simulation for a factory layout? I know the second question should precede the first, but the first is my priority.
Henry,
Did you check out Machine Analysis & Transportation Analysis in AutoCAD Factory as Xuesong suggested in his reply? You need to create a station for each asset in order to perform the analysis. A station has a property for Energy Consumption Rate. Can you let us know if it solves your issue?
Jun
