Hi.
I need to put 2 connectors at the same point. The goal is that when you insert the part, can put in two positions: normal position and symmetrical position.
The problem is that when you put the 2 connectors, only one is inserted in the set. I can't choose which I want to insert...
Currently, there is no way to switch the connectors when place asset. Well, we have recieved a few of the requirement as you. We will consider the function in the future release.
I am interested in the design (normal position and symmetrical position)you mentioned. Could you please share the snapshot with me(xuesong.bai@autodesk.com)? So, I want to investigate any workaround for that.
-Xuesong
Hello Miguel,
this could help you. Simply put two connectors
onto the far ends of a line and lateron edit the
lenght variable to get the points to be placed onto
each other.
Might be working for you
Kind regards
Daniel
Hi Daniel.
Yes I can put the two connectors on the same point. The problem is that when I insert the piece, only operates one of the two connectors. I can't choose between one and the other. Only work one connector...
Thank you!!!
Hello Miquel,
would´nt it be possible to just change the
parameter of the independent connectors
right after you connected all your assets?
Perhaps I´ve been getting you wrong, but
I think this should be working fine for you.
kind regards
Daniel
