If you have installed Navisworks 2015 SP1 against FDS 2015. Please make sure to insall this hotfix
which is addressing the crash issue this SP1 introduced.
thanks,
Irene
Hi Irene,
I am having the issue after installing the sp1 for navisworks manage thru FDS 2015. The hotfix link referenced below leads to a missing page. Is there somewhere I can get this hotfix from.
Thank you for any assistance,
Bill Lane
Hi Xuesong,
I will check it later. I was going to uninstall the service packs in the meantime, but in order to do that it says that I would have to uninstall navisworks manage and I don't want to go thru the uninstall reinstall process today. The reason this is urgent for me is that I have the batch utility set up to run at night to create new .NWD files. It will not work because with this error the batch program cannot open manage. Hopefully the hotfix reappears soon.
Thank you,
Bill Lane
Yes, the link has been changed as:
Currently the download-able installer just can work after NW 2015 SP1 installed.
we are re-posting the installer which can work based on SP1 or SP2 installed.
thanks,
Irene
Hi everybody,
I have installed the hotfix FDS19101 on Navisworks Manage 2015 SP2 to fix the problem with missing Factory ribbon and it worked. But after I have installed the SP3 for Navisworks the Factory ribbon is missing again. Is there any other hotfix or workaround to resolve this issue? (Of course I can uninstall the SP3 as well...)
Thanks, Martin.
yep another hotfix: http://knowledge.autodesk.com/support/factory-design-suite/downloads/caas/downloads/content/hotfix-n...
DarrenP
