I have been trying to install the hotfix FDS19103 repeated times now. It sits at Initializing. Windows Update is up to date. I do have NWSP3 and FDSUtils Update installed. I wasn't sure on the FDSUtils update, so I reinstalled both the FDU_UP1.EXE downloaded from http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/autodesk-fa...
and the Factory_Design_Utilities_2015_Feature_Update_Pack_EN.exe downloaded from Subscription. These may be the same thing, because I saw no difference in the Control Panel after installing.
I also noticed that in my Task Manager, two Setup.exes are launched when I click the FDS19103.exe.
I was able to install the FDS19201 in about 60 seconds.
Any suggestions?
Solved by wangcha. Go to Solution.
HI Dennis
That hofix is only for the users who installed FDS 2015 RTM + FDU_UP1 + Navisworks 2015 SP3, in that case Navisworks Factory environment cannot be initialized correctly. If you have installed Factory_Design_Utilities_2015_Feature_Update_Pack_
-Charles
Hello there,
I also have an issue with an update...
The 3DMax Design 2015 Extension 1 can be installed over and over again,
it´s been prompting anew after installation and a restart, reporting to not
be installed.
Kind regards
Daniel
