Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
FDS19103 Will not Install
2 REPLIES 2
dennis
492 Views, 2 Replies
I have been trying to install the hotfix FDS19103 repeated times now.  It sits at Initializing.  Windows Update is up to date.  I do have NWSP3 and FDSUtils Update installed.  I wasn't sure on the FDSUtils update, so I reinstalled both the FDU_UP1.EXE downloaded from http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/autodesk-fa...
and the Factory_Design_Utilities_2015_Feature_Update_Pack_EN.exe downloaded from Subscription.  These may be the same thing, because I saw no difference in the Control Panel after installing.
I also noticed that in my Task Manager, two Setup.exes are launched when I click the FDS19103.exe.
I was able to install the FDS19201 in about 60 seconds.
Any suggestions?
2 REPLIES 2
wangcha
in reply to: dennis
HI Dennis
That hofix is only for the users who installed FDS 2015 RTM + FDU_UP1 + Navisworks 2015 SP3, in that case Navisworks Factory environment cannot be initialized correctly. If you have installed Factory_Design_Utilities_2015_Feature_Update_Pack_EN.exe the issue would be gone. so based on your description, you don't need to apply FDS19103.
-Charles
Logos_Atum
in reply to: wangcha
Hello there,
I also have an issue with an update...
The 3DMax Design 2015 Extension 1 can be installed over and over again,
it´s been prompting anew after installation and a restart, reporting to not
be installed.
Kind regards
Daniel
Dogs aren´t flammable.
