Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
FDS UPDATE
9 REPLIES 9
Message 1 of 10
1453 Views, 9 Replies
FDS UPDATE
still do not understand why not update..
9 REPLIES 9
Message 2 of 10
jeff.pek
HI Ahmet -
What is this referring to?
Were you not able to access the update?
Jeff
Message 3 of 10
I downloaded all update files.Then i installed all.
Look at first picture.FDS update didnt install.
Message 4 of 10
jeff.pek
Do you know which updates were installed? How do you know that the update didn't install?
Jeff
Message 5 of 10
in reply to: jeff.pek
look at the attachments
Message 6 of 10
jeff.pek
Yes, did that. But exactly what you did, and what you saw is not clear.
Thanks for adding some clarification.
Jeff
Message 7 of 10
In the second picture warns "fds update" seems to be achievable. But I did download and install the file. Loading seems to still not installed.
Message 8 of 10
jeff.pek
Can you tell me which update is shown when you click on the notification icon in Launch Pad? You appear to have successfully installed FDS SP1 -- is that the update that it's showing you? If so, perhaps there's a problem with the notification icon that we need to look into.
Jeff
Message 9 of 10
Klein_Yang
Hi Ahmet, That's a known defect in LaunchPad 2014. The notification icon will still visible even if the FDS 2014 SP1 is installed. Thanks, Klein
Message 10 of 10
aguitton116
in reply to: Klein_Yang
Is there any chance to have a hotfix for this ?
