Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Failed to get the default dwg template
3 REPLIES 3
JamesThorpe4547
1659 Views, 3 Replies
I have multiple templates in the template folder,ACAD is pointing at that folder!
3 REPLIES 3
Hi there,
Could you please read the thread in another same topic?
http://forums.autodesk.com/t5/Autodesk-Factory-Design-Suite/Can-t-publish-asset/td-p/3533150
-Xuesong
Please mark as a solution if somehow I got it right.
I copied  both the English and Metric folders into the Vault template location.
Bingo.
Thank you.
Hi Guy´s
A little comment to the above.
I had the same problems after installing Factory Design Premium with Inventor-2017-SP1. I tryed to copy the Metric templates with little luck.
Finally I updated Inventor to 2017-R2 and after that it work fine.
Claus
Tags (1)
