Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
FACTORY FORMULATION FOR ENERGY
2 REPLIES 2
jorge.lopera
503 Views, 2 Replies
Hi, I'm trying to understand what is mean of the different report results of "transportation" and "Machine".
I am trying to reproduce a concrete batch plant with 2D Layout factory.
I have a Sand BIN, a Cement Silo and a Concret Mixed.
To try I put the Mixer with a energy consumption 1kW.
Then at the Routings for the operation of mixer I put 60minutes.
There are two Mixer Jobs, then I think could be 120 minutes.
When I display the "Machine" report appears 250KWH.
I have tried every way, and cannot understand why happens this.
Any idea?
Attached the file.
Technical Specialist
Nexsys de Colombia
2 REPLIES 2
XuesongBai
in reply to: jorge.lopera
Let me explain that:
Total Power Consumption (kW.h) = (setup time + processing time) * Part Quantity * Energy Consumption Rate at each operation for all jobs
(Unit of setup and process time should be converted to Hour.)
For Job arena:
Step time =0+0=0
Process Time=0+60min=60min=1hour
Total Power Consumption (kW.h)_arena=(0+1hour)*150*1KW=150KW.H
For Job cemento:
Step time =0+0=0
Total Power Consumption (kW.h)_cemento=(0+1hour)*100*1KW=100KW.H
So Total Power Consumption for all jobs= 150+100=250KW.H
-Xuesong
Please mark as a solution if somehow I got it right.
jorge.lopera
in reply to: XuesongBai
Thanks Xuesong,
It is enough to solve my question.
Do you think that this equation may be explained at wikihelp?
Nexsys de Colombia
