It seems like there is no download link for FDS Standard 2015 at Virtual Agent. I need to download it for my customer urgently. Is there a solution for that? Also when I click the links for FDS Premium 2015 it gives the error "File not Found".
Between our customer is not on subscription.
Cheers,
Solved by camilo.lemos. Go to Solution.
Hi @Anonymous
Thank you for the heads up! I'll ask the team to add the download links to the Virtual Agent.
Meanwhile, are you looking for the 32 or 64-bit version of suite? Also, what language are you looking for?
Thank you,
