I have autocad 360 pro and factory design.
recently when I try to edit a line, etc, it lets me edit in freeform for example drag the line from one spot to another, but if I want to put in an exact dimension, the drawing starts zooming out and moving up and down and the number pad to type the value becomes unresponsive.
Solved by guosu. Go to Solution.
Dear customer,
Thank you for submitting the issue against Factory Design. We can reproduce the issue you described. This issue is iOS 8 special issue. We will set about investigating and solving it.
Best Regards,
Factory Design Team
Autodesk, Inc.
