Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Factory Design and Acad
3 REPLIES 3
579 Views, 3 Replies
I have instaled Factory Design and when i want to use Acad it opens Acad Mechanical.
I don't want to use Mechanical.
Can i open Acad instead of Mechanical?
3 REPLIES 3
XuesongBai
Currently, the Factory design is not supporting AutoCAD.It works both in AutoCAD Mechanical and Architecture now.
So,thank you very much for the  we are considering this functionality as candidates for a future release of Factory Design Suite.
-Xuesong
Please mark as a solution if somehow I got it right.
I've discovered Acad works within Factory Design.
You can start Acad by going to Start, then Programs, then Autodesk, then AutoCAD Mechanical, and you'll find a link that starts Acad.
Drawings made ​​with this Acad can be  loaded in Factory Design.
I thought you should know this.
XuesongBai
Thank you very much for following up the info.
-Xuesong
