I have an assembly built prior to FDS. Now that we have FDS, is there a way to make it an Asset? When I open the assembly, I get the Factory tab, and it appears to be allowing me to select a Landing Surface, but my Asset Builder button on the Environments tab is faded out.
Will I need to start over with the assembly?
Solved by XuesongBai. Go to Solution.
Hi there,
I guess that your assembly is created based factory layout template.
If yes, that is the limitation that you cannot publish the such assembly as asset.
But you can create a normal assembly and then publish it as assset in Asset builder environment.
-Xuesong
You got it Xuesong. I finally got a msgbox that pointed out that the original template was the culprit.
