Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Error message when publishing
16 REPLIES 16
Message 1 of 17
Logos_Atum
860 Views, 16 Replies
Hello there,
due to our change to the 2014 version of FDS I needed
to republish some assets. One of them kicks out an error
message.
It´s in German but I will try to translate it. Perhaps you
know what I´m talking about by the look of the requester:
"When trying to copy or save the objects data to the working
folder an error occured.
The object link has not been set/linked to an object instance.
Publishing process has been canceled"
I´ve attached the window.
Thanks in advance
Daniel
Dogs aren´t flammable.
16 REPLIES 16
Message 2 of 17
XuesongBai
in reply to: Logos_Atum
 Hi Daniel,
Could you give a try  to delete the links in the thrid part  folder in model browser?
-Xuesong
Please mark as a solution if somehow I got it right.
Message 3 of 17
Logos_Atum
in reply to: XuesongBai
Hello Xuesong,
they´ve been removed.
Does not work nontheless.
Kind regards
Daniel
Message 4 of 17
XuesongBai
Hi Daniel,
Could you please send me the asset to me ?
-Xuesong
Message 5 of 17
Logos_Atum
Hello Xuesong,
it´s been sent.
Kind regards
Daniel
Message 6 of 17
Logos_Atum
Trouble has been caused by an equation and a referece too much.
Inventor can´t handle this. After removing the parameter everything worked fine.
Thanks again to Xuesong.
Message 7 of 17
Miquel
I have the same problem, even with a simple part (a cube) without parameters
Message 8 of 17
Miquel
in reply to: Miquel
the problem occurs only if I publish the 2d. If disable this option works correctly, the problem is that I can not publish the 2d ...
Message 9 of 17
XuesongBai
in reply to: Miquel
Hi there,
Sorry for the issue that taken to you.
I think the reason is not same as Daniel.
Maybe you have change the setting of path of Inventor template. As default, Factory will use the following template(depends on which unit you are using) to publish the 2D asset
  • C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates\Metric\ANSI (mm).dwg
  • C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates\English\ANSI (in).dwg
-Xuesong
Message 10 of 17
Miquel
The templates can be only configured with dwt, no dwg. So I tried it with a dwt template and still not working.
Message 11 of 17
XuesongBai
in reply to: Miquel
The dwt template is not used for publishing the 2D asset.
The following setting are used for publishing 2D assets.
And make sure, you are using the default template in Inventor project.
-Xuesong
Message 12 of 17
Miquel
Please watch the video
Message 13 of 17
XuesongBai
in reply to: Miquel
Hi there,
Thank you for sharing the video.
I guess that you are installed the language packs in your English version, right? Could you please tell me which language you are using(I am sorry I cannot difference the European language )?
-Xuesong
Message 14 of 17
Miquel
the problem only happens with specific ipj, with the rest working properly ... in all cases the templates are the same ...
The language pack installation is the default, in Spanish.
Message 15 of 17
XuesongBai
in reply to: Miquel
Could you please create the "Métrico" folder or "Inglés" at "C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates"?
  • And copy ANSI (mm).dwg and ANSI (mm).idw from "C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates\Metric" to "C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates\Métrico"
  • or copy ANSI (in).dwg and ANSI (in).idw from "C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates\English" to "C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates\Inglés"
By the way, "Métrico" template is for publish asset with metric units(eg. mm). "Inglés" template is for publish asset with Imperial  units(eg, inch)
-Xuesong
Message 16 of 17
Miquel
I want to send you a video but the size is very large, as I can send?
Message 17 of 17
XuesongBai
in reply to: Miquel
You can send the file to my email by Xuesong.bai@autodesk.com
