In Inventor with FDS2014, when I select the View 2D Representation button from the Publish Preview of an asset, i get "DWG TrueView is not registered". What do I need to do? I do have DWG TrueView 2014 installed.
Solved by DarrenP. Go to Solution.
i was not able to reproduce this
try running a repair or reinstall of dwg trueview
DarrenP
I had to do a uninstall, deleted folders and then re-downloaded the install exe and then installed Back working now
