Hi
This is the first time I have had a problem with my asset library, I hope you can help.
When I insert an asset, it shows the object, and I can even specify where it should be placed. After I tell it at which degrees to place it, I get the following error message:
"The database being opened from the OldVersions folder has an invalid filename."
Regards
Anina
