Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Contact solver is not working with FDS factory assets
2 REPLIES 2
strijkp
456 Views, 2 Replies
Is someone aware that the Inventor's contact solver is not working when making a contact set of Factory Assets. No collision is detected!
Did the test with the same files but then imported in a regular assembly as regular parts, and that works fine.
Any suggestion to make this work in a Factory layout?
2 REPLIES 2
jeff.pek
in reply to: strijkp
Hi Peter -
Is it possible for you to make a video of what you're doing?
  Jeff
XuesongBai
Hi Peter,
The contact solver is conflict with Snap fuctionality in Factory layout. So you can disable the "Snap" functionality in Factory Options.
-Xuesong
Please mark as a solution if somehow I got it right.
