hai , How to use connenctor properties in factory design suite..? by using asset variants and fx parameters.?
Solved by jeff.pek. Go to Solution.
Solved by XuesongBai. Go to Solution.
Hi -
Thanks for the question.
We have some info regarding connector classes, and connector class properties, in the documentation.
Maybe we can help answer some specific questions you have.
Can you let us know what you're trying to accomplish?
Jeff
Hi there,
Attached is the brief workflow document to introduce the connector and connectorclass.
-Xuesong
Hi -
I'm pretty sure that you don't have face-level selectability in Navisworks itself.
To do this, you'd have to make this change in Inventor, and then the color override should be maintained through the Navisworks import.
Jeff
Thanks again, I need to insert the trees and plants in my model in navisworks, if import from inventor its not showing, but when i generate into video that trees are showing. how i show my trees in navisworks can you explain please. can you tell the best reccommend export video option of material and in autodesk rendering not in presenter.
Mathavan H
Hi. Thanks I tried that file.
Very Sorry I cant understand properly. So Please send any other files or videos links.
Thanks in Advance
