Hi!
I' ve installed the FDS and the connector classes are installed in C:\ProgramData\Autodesk\Factory Design Suite(version)\FactoryLibrary.
I can centralize the connector classes on the server so all clients reads them? If it is possible how could I do it?
Thank you very much.
Best regards.
Hello Sato,
Yes, you can do that.
The first way is that you need to map the network location and then set the drive in Factory Options>-Assets (Currently the library path can not be network location path)
The other way is that you can set the library which is based on Inventor project and the library path can be network location path.
So you can put ConnectorClass folder with all of the connector class file in the root folder.
-Xuesong
