Hello there,
using connector classes has helped a great deal but now i came across a case where i need some help.
I created an asset in which a text parameter is used and a i logic rule which assigns a width to the text parameter.
As the defining rule is different than that of the text parameter the width in the text parameters value is not properly communicated by the connector points.
I need:
The text parameter to be acknowledged as the real width in the connected part.
I thought about doing a control sketch with another parameter to sidestep the problem but i can´t quite place it yet...
I hope for good news 😉
Have a good time
Daniel
Hello Daniel,
That will be great if you can share the data with me. So that that will same my time to prepare the such data.
-Xuesong
Hello Xuesong,
i will be mailing you the dataset on friday.
Thanks so much
Daniel
Hello Xuesong...
i´ve prepared the files and sent you a pack and go of the dataset including the connector classes needed.
I´ll be glad to be hearing from you
Kind regards
Daniel
