Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
Connection Orientation Failure
7 REPLIES 7
Message 1 of 8
nstalker
870 Views, 7 Replies
I am having problems getting two user assets to connect properly.  It seems like I have tried every possible orientation of  X,Y and Z to no avail.  These are parametric guardrails similar to the guardrail in the system assets.  I tried to even make the connection points in the same orientation as the system asset but it does not work.  The system assets attach to each other fine so I don't know what I'm doing wrong.
7 REPLIES 7
Message 2 of 8
ted.saufley
in reply to: nstalker
nstalker,
Is this what you're trying to achieve? (See attached.) I was unable to replicate your problem.
-Ted
Ted Saufley
Principal Content Developer
DLS Manufacturing Engineering
Autodesk, Inc.
Message 3 of 8
nstalker
in reply to: ted.saufley
Yes but mine will not connect that way. I'm not sure why.
Message 4 of 8
ted.saufley
nstalker,
Please check your Snap settings in the Factory Options dialog box. (See the attached image.)
-Ted
Ted Saufley
Autodesk, Inc.
Message 5 of 8
nstalker
Ted,
Thank you for your response.  How do I get to the Factory Options dialog box?
Message 6 of 8
ted.saufley
If no layout is currently open, click Get Started tab > Factory Launch panel > Factory Options.
If you do have a layout currently open, then click Factory tab > Options panel > Factory Options.
Ted Saufley
Autodesk, Inc.
Message 7 of 8
nstalker
Thanks Ted!  I adjusted my settings to be like yours and I still have this problem (see attached)
Message 8 of 8
XuesongBai
The problem is that the direction of X , Z axis  are not correct when you change the asset variant as 8ft_1_Post. Please make sure the +Z direction is vertical to the landing surface, whilst +X direction is along with the way of chain. Please give a try to the asset I edited as attached.
-Xuesong
Please mark as a solution if somehow I got it right.
